Warm-reset
agustinmar
Hello, I have a Cisco Catalyst 3550 switch and this switch is reboot for warm-reset. Could say me someone that is warm-reset?
Thank you and sorry for my bad english.
mishra.rahul
The Warm Reload feature allows users to reload their routers without reading images from storage. That is, the Cisco IOS image reboots without ROM monitor mode (ROMMON) intervention by restoring the read-write data from a previously saved copy in the RAM and by starting execution without either copying the image from flash to RAM or self-decompression of the image. Thus, the overall availability of your system improves because the time to reboot your router is significantly reduced.
Check link for more Info and Commands for warm reloading Cisco Devices
http://www.technicafe.net/2012/05/warm-reload-reboot-your-cisco-router.html
10 Replies 10
leonvd79
Level 4
Level 4
If you issue "reload" from the CLI for instance, that is considered to be a warm-reset.
Thank you for all.
ankurbhasin
Level 9
Level 9
Hi Friend,
If you reload the switch via software (IOS) using commands it is considered as warm reset and incase you just take out the power cord or something related it is considered as cold reset or cold restart.
HTH, if yes please rate the post.
Ankur
jarathbu
As an analogy, summing up the previous posts.
From a windows PC - if you Ctrl-Alt-Del -> restart that is a warm reset. If you pull the power cord or turn of the PC that is a cold reset.
James
Thank you for all.
Thanks for taking it as a genuine answer, Actually I worte this topic on my blog.
Rahul Mishra
{edited due to misunderstanding, my apologies]
Thanks alot for Understading
Regar
Rahul Mishra
No problem at all. I've edited my post above, and you can do the same, or even delete if you deem appropriate.
Thank you for the nice rating and good luck!
mishra.rahul
