dan
Community Member
Was given Cisco 1720, need to interface it between DSL modem and small LAN
I was recently given a cisco 1720 router by a client who owes me a great deal of money. I would like this router to allow use of my 7 computers ( all on a 3 com superstack hub)with my DSL modem and bell south fast access ( DSL) line. The software that was provided is old, and does not support windows 2000 ( I have the Advanced Server version), and I am hoping someone here can point me to some "wizard based" configuration routine a non-programmer could use to make this work. The dsl modem is a Wirespeed by Westell.
Can someone give me helpful advice on this, or point me to a site that would help--Cisco pages have so far not helped me.
1 REPLY
Community Member
Re: Was given Cisco 1720, need to interface it between DSL modem
You have at least two options that I can think of, neither of which are ideal. To start, you could search on CCO for the password recovery procedure. This involves overwriting the existing config file. The first time that you boot after that, the router will prompt you to enter config mode. This allows very basic setup from an interactive prompt. Can't say for sure if it is enough to get you going but it probably would be. Second, there is Router Software Loader (RSL). I am not a big fan of this either, but it seems to be more functional than the aforementioned config mode. You will need all of the passwords to use RSL, so you may need to do the password recovery procedure either way if your customer didn't provide them.
Here is a link for RSL. There is a hotlink to the download site a page or two down from the top.
Good luck.
http://www.cisco.com/warp/public/779/smbiz/service/knowledge/general/rsl.htm
149
