WCCP IP spoofing problem
hari_bhr
Hi all
I have cisco 3640 with 2 FE
iam trying to integrate with Cache Engine
But i see most of the example shown with 3 interface
That means, i should have much 3 interface
or still i can do with the 2 Interfaces
transparent cache is working...
when i want to do ip spoofing,
iam not able to achive , because of some limitation of 3 interface of Ethernet
Please Advice
hari
ebreniz
Level 6
Level 6
A router with 3 interface is necessary for IP Spoofing with WCCP. This is because the router has to redirect the packets to the same CE for both - the traffic from the client to the web-server and for the traffic coming back from the web-server to the client.
Can have some work around if you don't have a similar router,
1)All three interface need not to be Ethernet/FE, the router interface connecting to the WAN/Internet could be a WAN interface.
2)If a three interface router is not available, a work around could be to use sub-interfaces on one of the physical interfaces.
For more information about IP Spoofing with WCCP, please. refer to -http://www.cisco.com/univercd/cc/td/doc/product/webscale/uce/acns51/cache51/transprt.htm#1038384
