The router details are:
Router#sh ver
IOS (tm) 3600 Software (C3640-IS-M), Version 12.2(1a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Sat 26-May-01 00:55 by pwade
Image text-base: 0x60008950, data-base: 0x61158000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (f
c1)
Router uptime is 16 weeks, 5 days, 22 hours, 45 minutes
System returned to ROM by reload at 12:28:34 GMT Tue Oct 30 2001
System restarted at 12:32:53 GMT Tue Oct 30 2001
System image file is "flash:c3640-is-mz.122-1a.bin"
cisco 3640 (R4700) processor (revision 0x00) with 59392K/6144K bytes of memory.
Processor board ID 24222352
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
35 Serial network interface(s)
1 ISDN Basic Rate interface(s)
1 Channelized E1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
The Bandwidth of the circuit should be 128Kbps but the report shows over 192kbps, this is on the Mulitlink and on the serial as well. We have other routers with Multilink and they are reporting fine (different IOS)
