Community Member
Web Interface for Cat4k Sup-3 ? Sup-2 ?
Does the Catalyst 4006 Sup-2/3 have a web interface that allows full configuration of the switch? I have Cisco Works for Windows and CiscoView v5.3, but the configuration options there are limited. Some of the options are not even supported. I have the latest patches for the Sup-3 engine from CCO.
thanks.
Re: Web Interface for Cat4k Sup-3 ? Sup-2 ?
Web interface is supported on Sup2
http://www.cisco.com/warp/public/473/105_15954.shtml
Not supported on Sup3 yet
Community Member
OK, thanks for the reply. I have a network of One Cat4k-Sup-3 and 2 Cat4k Sup-2's. My VLAN config's are managed via VTP on the SUP-3 box, so a web interface on the Sup-2's is not *that* much help.
Awaiting the Sup-3 web interface.
thanks.
95
