weird IP problem
We have two routers connect to a layer3 switch. We've assigned 255.255.255.240 subnet to interfaces which connects routers and layer3 switch as follow.
Router1-eth0 Router2-eth0
*.193/28 *.209/28
*.194/28 *.210/28
Layer3 switch
The problem is that it seems like layer3 switch is translating outside ips(connecting to port80/21) to IPs within subnet that aren't used by interfaces.
For example,
Let say, the client has IP of 24.24.24.24. The client IP will change to *.214 or any unused IP if he connects to port 80/21 on our web server
I don't understand why is doing.. :(
Can anyone shed a light on this??
Thank you
1 REPLY
Re: weird IP problem
Problem solved...
It wasn't really translating IP. Our IDS system rule cause the problem.
Thank you for you time...
90
