Weird Problem with LS1010 ATM switch and 2 routers on each side
rdemello
I have a TAC case open with this, but I wanted to see if I could get some ideas from anyone here. All documented configuration is v. simple and straightforward, but something is amiss. Any pointers, advice would be great:
Here's a diagram of what we have set up. Very simple setup we have:
maingw7500 LS1010 Loaner3600
atm5/1/0.40 -------atm0/0/0 | atm0/0/1 -------atm1/0.50
pvc3/40 ------------ pvc 3/40 pvc3/50 ----------pvc3/50
Now for the interface configs on the routers and the entire config of the LS1010:
VGW7500 (IOS Version 12.0(9)S)
interface ATM5/1/0
no ip address
no ip directed-broadcast
ip route-cache flow
no ip route-cache cef
no ip route-cache distributed
atm uni-version 3.1
no atm auto-configuration
atm ilmi-keepalive
no atm address-registration
atm ilmi-pvc-discovery
interface ATM5/1/0.40 point-to-point
ip address 150.240.45.1 255.255.255.252
pvc 3/40
protocol ip 150.240.45.2
no ilmi manage
oam-pvc 0 ****NOTE**** here oam-pvc manage brings down the interface!
encapsulation aal5snap
Loaner3600 (IOS Version 12.1(5)T5)
interface ATM1/0
no ip address
ip route-cache flow
atm uni-version 3.1
atm ilmi-keepalive
interface ATM1/0.50 point-to-point
ip address 150.240.45.2 255.255.255.252
pvc 3/50
protocol ip 150.240.45.1
oam-pvc manage
SW1010_Lightstream(IOS Version 12.1(7a)EY3)
Current configuration : 1589 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname sw1010
enable secret 5 xxx
network-clock-select 1 System clock
sdm ipqos zero
sdm policy 0
ip subnet-zero
no ip finger
atm address 47.0091.8100.0000.0009.b71c.3e01.0009.b71c.3e01.00
atm router pnni
no aesa embedded-number left-justified
node 1 level 56 lowest
redistribute atm-static
interface ATM0/0/0
no ip address
interface ATM0/0/1
no ip address
atm pvc 3 50 interface ATM0/0/0 3 40
interface ATM0/0/2
no ip address
shutdown
atm uni version 3.1
interface ATM0/0/3
no ip address
shutdown
interface ATM0
no ip address
atm oam interface ATM0/0/0 0 16 seg-loopback rdi
atm oam interface ATM0/0/1 0 16 seg-loopback rdi
atm oam interface ATM0/0/2 0 16 seg-loopback rdi
atm oam interface ATM0/0/3 0 16 seg-loopback rdi
atm oam interface ATM0/0/0 0 5 seg-loopback rdi
atm oam interface ATM0/0/1 0 5 seg-loopback rdi
atm oam interface ATM0/0/2 0 5 seg-loopback rdi
atm oam interface ATM0/0/3 0 5 seg-loopback rdi
interface Ethernet0
ip address 150.240.150.154 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0
no ip http server
line con 0
transport input none
line aux 0
line vty 0 4
exec-timeout 120 0
password 7 xxx
login
end
NOTES:
- When the routers are terminated with a physical loopback they ping their own ATM ints just fine.
- All interfaces on the routers have been in production in recent past.
- 3600 interface stopped flapping when we extended its cable.
- Routers can ping their own ATM ints also when they are plugged into LS1010 AND the other LS1010 interface it is mapped to is plugged into itself with at physical loopback.
- 3600 can ping its own ATM int even when it is plugged into LS1010 AND 7500 is plugged into other LS1010 interface to which its mapped
- Also, on the LS1010, when we do a "ping atm interface atm0/0/1 3 50 end-loopback" command it works fine (this is with a normal setup like i just mentioned above), but the same "ping atm" command mapping to the 7500's interface and pvc does not work because we can't run OAM-PVC MANAGE on the 7500 sub-int without it bringing down the interface??
- Throughout this process we have occasionally been able to get pings through from the 3600 atm int to the 7500 atm int.
- We've tried many debugs, and one common debug message on pings is "encapsulation failed", but we have aal5snap defined on both ends of the PVC
- I know we don't need ILMI on a PVC, but it helps for debugging
- Both atm interfaces on the routers are set to CLOCKING=LINE, and the LS1010 is set to "Current clock source:System clock, priority:1"
Any advice or help would be appreciated!
Jason
uniemeyer
Jeson,
this is a little bit difficult to understand and I guess the only chance to find
out what's up is to use an ATM protocol analyser. The analyser can prove
which device causes the problem. You mentioned that it is not possible
to send "atm oam end-loopback pings" from the LS1010 in the direction
of the 7500 router because you need to set the interface to oam-managed.
This is not true. The interface has to reply on such pings even it is not set to
oam-managed.
Setting an pvc to oam-managed means that the router sends oam pings itself
on a regular basis over that pvc but has nothing to do with the reply on such
atm pings.
Are there any hints of errors in the "show controller atm ..." outputs? You
should check this. Config seems to be o.k. I believe the problem is with the
7500 cisco. Maybe you can do an IOS upgrade on that router.
regards Ulrich Marzoli
www.netaid.de
Thanks for the OAM-manage tip Ulrich. You are 100% correct. Actually we solved the problem by putting "atm scrambling cell-payload" on both LS1010 interfaces and both router interfaces, and circuit came up. However,
I still have one note and question though. Even though we can ping ip across the pvc in both directions now, on the LS1010, the "PING atm int atm 0/0/0 3 40 end-loopback" command does not work, however the same command for the 3600 does work, and they now have identical PVC 3/x configs. Any thoughts on that?
thanks,
Jason Evans
Hi Jeason,
I think that it is a problem with the IOS for the Cisco 7500 because this one is
in regard to the atm IOS development very old.
I don't know if the command "show atm pvc 3/40" is working on that router IOS.
This command shows the amount of received and transmitted atm oam looopback cells. The output is like this:
router#sh atm pvc 1/321
ATM2/0.321: VCD: 1, VPI: 1, VCI: 321
VBR-NRT, PeakRate: 14936, Average Rate: 14936, Burst Cells: 200
AAL5-LLC/SNAP, etype:0x0, Flags: 0x20, VCmode: 0x0
OAM frequency: 10 second(s), OAM retry frequency: 1 second(s), OAM retry frequency: 1 second(s)
OAM up retry count: 3, OAM down retry count: 5
OAM Loopback status: OAM Received
OAM VC state: Verified
ILMI VC state: Not Managed
VC is managed by OAM.
InARP frequency: 15 minutes(s)
Transmit priority 2
InPkts: 2249329431, OutPkts: 2331157430, InBytes: 2783771421, OutBytes: 2383249112
InPRoc: 20635871, OutPRoc: 28830950
InFast: 2228692502, OutFast: 2302309385, InAS: 0, OutAS: 0
InPktDrops: 0, OutPktDrops: 0
CrcErrors: 260149, SarTimeOuts: 0, OverSizedSDUs: 0
OAM cells received: 4124434
F5 InEndloop: 4123136, F5 InSegloop: 0, F5 InAIS: 1281, F5 InRDI: 17
F4 InEndloop: 0, F4 InSegloop: 0, F4 InAIS: 0, F4 InRDI: 0
OAM cells sent: 4134409
F5 OutEndloop: 4133128, F5 OutSegloop: 0, F5 OutRDI: 1281
F4 OutEndloop: 0, F4 OutSegloop: 0, F4 OutRDI: 0
OAM cell drops: 0
Status: UP
This command is most helpfull becaus it shows also the SAR CRC errors
per PVC. So you can find out where the CRC errors on the interface come from if the problem is not related to the access line. But this is more related to WAN links with several PVCs.
www.netaid.de
