What are the types of connectors required for cisco 2500 router
prithvirajkg
I have some cisco 2500 routers. But I do not have the cables to connect to LAN and WAN. Pl help me to get the cables, the suppliers in Mumbai, India
Phillip Remaker
The LAN connector is just a 15 pin AUI, so you need a 10Base5 to 10BaseT converter.
Web search: aui 10base T transceiver
The WAN cables are all based on Cisco's 5-in-1 HD-60 format.  Depends on what you want to attach to.
Web search: Cisco HD-60
