Webcast-Catalyst9k
What cable do I need for a PA-A3-T3 DS3 port adapter?
Can I use a RG-6 75 OHM cable with a BNC connector?
Do I have to use a RG-59 75 OHM cable?
Anonymous
N/A
Re: What cable do I need for a PA-A3-T3 DS3 port adapter?
You should use an RG-59 BNC.
RG/6 cable is preferable to RG/59, and will give you greater maximum distances. Bottom line is that any 75 ohm cable will work within its loss and shilding limits.
Regards;
Doug
181
