What command do I use to be sure my BRI and PRI backups for frame relay drop when the frame comes back up?
I want to be sure the ISDN drops when the frame comes up, not just when it sees no traffic across the ISDN interface. 6 sites with 1750s/BRI/Frame FT1 and a 3640/PRI/Frame T1. I'm using OSPF, static floating routes and dialer maps to trigger the ISDN connetions.
1 REPLY
Anonymous
N/A
Re: What command do I use to be sure my BRI and PRI backups for
With static floating route as your
backup mechanism, I'm afraid you'll
have to reply on idle-timeout to bring down the link.
You might want to set a value lower that the 120sec as default
but its not really recommended as slow application might cause the link to
timeout while in backup mode.
82
