09-09-2006 06:32 PM - edited 03-03-2019 04:54 AM
Is it possible to know which interface configuration I'm in? Sometime I do many things and forget what this interface in interface configuration mode is.
09-09-2006 06:41 PM
Unfortunately, I don't believe it is possible for you to have this information... The prompt will just show "config-intf" regardless of which interface you are configuring .
Paresh
09-09-2006 07:10 PM
Try this.
Type 'do show history' and the last 'interface (type_#)' is the mode you are in. Here's a lab example. As you can see, I am in interface fastethernet0 mode.
Router(config)#int f0
Router(config-if)#do show hist
int f0
do show hist
Sundar
