What is 2621 memory and IOS requirement with ATM DS3 module?
What is 2621 memory and IOS requirement with ATM DS3 module? I need help to find out what type of DS3 card I can use with 2621 and what will be the memory and IOS requirement.
Currently, I have following configuration:
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(4)T1, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Thu 25-Oct-01 19:25 by ccai
Image text-base: 0x80008088, data-base: 0x80A34C28
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
SFR1RA01 uptime is 13 weeks, 1 day, 13 hours, 44 minutes
System restarted at 01:45:40 PST Sun Mar 30 2003
System image file is "flash:c2600-i-mz.122-4.T1.bin"
cisco 2621 (MPC860) processor (revision 0x101) with 60416K/5120K bytes of memory.
Processor board ID JAD05370CCV (2497770141)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Re: What is 2621 memory and IOS requirement with ATM DS3 module?
You will need a min of IP plus software for supporting this module.
The module u need is NM-1A-T3
Min memory requirements for the above configuration that you have (2 port serial ) and 12.1(3r)T2 IOS, you ll need,
48 MB of system ram, you already have 64 mb. (20 percent memory allocated for IO - "memory-size iomem 20" command in global configuration mode required (also requires reload to take effect)
You have got enough flash too (32 Mb, required amount is 16 mb)
If you are upgrading to 12.3 IOS, (IP Plus minimum), then you will need 64 mb ram, 10 percent memory allocated for IO.
Hope tht helps!
Thank you for your help. This is a great place to get faster help.
117
