Community Member
What is accounted for in statistics on frame-relay sub-interfaces ? (ex.: drops, compression, etc)
I have discordance in reported statistics via snmp for links (Frame-relay sub-interfaces) from Router A to Router B on point to point links. Router A is linked to 3/4 Routers in a hub and spoke network, the stats are not close on the most used sub-interfaces in some case 80 % difference. What is accounted in these stats ?
1 REPLY
Anonymous
N/A
Re: What is accounted for in statistics on frame-relay sub-inter
The stats should show any data that
passed; this would include layer3 data,
routing updates, CDP, etc.
You should ensure that you are running
recent code, just to minimize the chance
of you seeing some statistic bugs.
112
作成コンテンツを作成するには してください
