Community Member
what is rstp port delay
hi
i want to know rstp port delay
skrao
Community Member
Re: what is rstp port delay
hi,
stp port delay is 50 seconds. then what is rstp port delay
regards
skrao
Community Member
Under IEEE 802.1D STP will normally converge within 50 seconds comprising of 20 second Max age time + 15 seconds in the listening state + 15 seconds in the learning state.
Under IEEE 802.1W a port can immediately transition to the forwarding state if an alternate Root port has been selected.
HTH.
Phil.
Community Member
Just to add,
I believe that the max age timer would still need to expire though so I think it would be 20 seconds.
Regard,
Phil.
104
