Webcast-Catalyst9k
What is the best way to CiscoView a cluster and snmp syntax for cluster
Hi All,
I have several clusters using a combination of 2900xl and 3548xl. They use one ip address via the command switch. When I run CiscoView I only see the command switch. What is the correct snmp syntax for CiscoView of cluster? Or is it that I must have an ip address for each member and use stackmaker? Thanks in advance
Mark
1 REPLY
Blue
Re: What is the best way to CiscoView a cluster and snmp syntax
In order to view the XL clusters, you need to use the CMS/CVSM:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/29_35wc/sc/swgcms.htm
Cisco View requires that you assign an individual ip address for each device that you're trying to open up.
116
