What is the easiest and most graceful way to disconnect a call on a PRI?
admin_2
Level 3
Level 3
I have a 4500 router with a PRI card in it. There are about 15 sites that we can call out through the PRI to. If I have a call up, I have been shutting down the D-channel (s0:23) to disconnect the call. However, if there are 2 calls going on at the same time, then using this method, both calls will be disconnected. How can I disconnect a single call on a PRI without shutting the D-channel down?
Not applicable
Try "clear int s0:X", where X is the number of the B channel they're on (not 23).
ali-franks
OR
isdn disconnect interface serial 0/0:x all
where x is the interface
Ali
ali-franks
oops - connection prob!!
