What is the max serial interfaces I can use with MLP
I want to use MLP on 6-8 serial interfaces that are running over a chanellized DS3.
What is the max serials I can run it over?
Are there any known issues with running over a fractional DS3?
1 REPLY
Anonymous
N/A
Re: What is the max serial interfaces I can use with MLP
MLP performance depends on the platform
being used. If you have a DS3, you
must have a larger end platform, in
which case 6-8 should not be a problem.
The 7200, for example, could support
16 T1s in any combination without
WFQ (use FIFO), interleaving, fragmentation compression.
Adding Fragmentation and WFQ will cut
capabilities in half or greater.
91
