what's the difference between catalyst6500 and cisco router 7600?
Now catalyst 6500 converge the 7600 module and even has the flex wan interface, and router 7600 also converge the cat6500 module,superengine module and fabric switch as well.
So now they looks very smilliar ,even same. I am so confused what's the difference between them , also what's the difference between these kind of routing switch and switched router now?
If I am going deploy a 10G MAN , which one is more suitable?
Is there any document really explain it deeply?
david
Re: what's the difference between catalyst6500 and cisco router
The difference is rather simple: OSM. A 7600 is a 6500 with SUP2/MSFC2/PFC2 and at least one OSM. The rest is
marketing.
Gold
cat65k will only handle up to an oc-3 linecard in the flexwan module. the 7600
will go higher. What technologies are you hooking up on your 10 gig ? DWDM ?
It will be 10Giga ethernet, so is there any difference to use 7600 and 6500?
Gold
from that perspective, no. We use both, with any high speed wan stuff going on the 7606's and lan stuff on the 65's just keep the caveat about flexwans in mind.
david
I haven't seen anything about differences in the FlexWAN. Do you
have a reference for this claim?
I digged into the modules of cat6500, I found the cat6500 also support oc48.The only difference between cat6500 and router7600 on modules is 7600 support channelized OC module, the cat6500 don't, it only support POS OC module.
224
