What's the real difference between point-to-point and multipoint int type
teru-lei
Hi All,
Does any body know the real difference between point-to-point and multipoint interface type? I just know that when you use point-to-point in frame-relay etc, you can not connect to two peers (so in frame-relay, you can just config 1 virtual-circuit). So I usually set the interface type to multipoint when I config subinterface. Because I think multipoint is better for the reason above. But is there any feature that point-to-point can do but multipoint can not? Thank You!
Best Regards
Teru Lei
tepatel
YES..point to point is for one PVC only while Point to multipoint is for more then one PVCs on a same interface. Also the difference is in how PVC gets learnt on p-to-multipoint interface.
Point-to-point subinterface : With point-to-point subinterfaces, each pair of routers has its own subnet. If you put the PVC on a point-to-point subinterface, the router assumes that there is only one point-to-point PVC configured on the subinterface. Therefore, any IP packets with a destination IP address in the same subnet are forwarded on this VC. This is the simplest way to configure the mapping and is therefore the recommended method. Use the frame-relay interface-dlci command to assign a DLCI to a specified Frame Relay subinterface.
Multipoint networks - Multipoint networks have three or more routers in the same subnet. If you put the PVC in a point-to-multipoint subinterface or in the main interface (which is multipoint by default), you need to either configure a static mapping or enable inverse Address Resolution Protocol (ARP) for dynamic mapping.
Here is the url for more detailed explanation between those two.
http://www.cisco.com/warp/public/779/smbiz/service/knowledge/wan/subifs.htm
