What's wrong with PBR???
I need to make a simple PBR but it just don't seem to work. Let me brief you... I have router with a default route to another router connected to the internet, however i want that one host (192.168.127.2) jump to other router (think it like a rudimentary load-balance). But it just dont work... this is part of the conf:
interface FastEthernet8/0/0
+++ EXIT INTERFACE +++
ip address 10.0.100.1 255.255.255.0
full-duplex
no ipv6 mfib fast
mls rp vtp-domain xxxx
mls rp vlan-id 7
mls rp management-interface
mls rp ip
interface FastEthernet8/1/0
no ip address
full-duplex
no ipv6 mfib fast
interface FastEthernet8/1/0.110
+++ IN INTERFACE +++
encapsulation isl 110
ip address 192.168.127.1 255.255.255.0
ip policy route-map test
no ip redirects
ipv6 address xxxxxxxxx
ipv6 enable
ipv6 nat
access-list 1 permit 192.168.127.2 log
route-map test permit 10
match ip address 1
set ip default next-hop 10.0.100.2
I even remove the defaul route just to see what'd happend with no positive results.... I highly appreciate your help
  • Other Network Infrastructure Subjects
Re: What's wrong with PBR???
Can you replace the "set ip default next-hop 10.0.100.2 " with "set ip next-hop 10.0.100.2 " and check it.
Actually I got to find information about this. It turns out that when CEF or dCEF is enable it just rule out PBR, in the moment I enter "no ip cef" PBR start working. I currently have IOS 12.3T2 ENTERPRISE for the 7513. Does any one know what IOS can I use to succesfully run PBR and CEF???
TIA
Bronze
Sounds like a bug, as I believe PBR has been CEF-capable for a good while now. Have you contacted TAC about this?
You are righ baranski it is a bug. Check bug # CSCdy06253. But it is supposed to be fixed however i recently upgrade to IOS 12.3(2)T2 in my 7513 and still. This is giving me a lot of headache because there are some features that require CEF (NBAR and such) but i also need PBR. Any more feedback on this issue will be thank.
Bronze
Is there a reason why you're using a bleeding-edge IOS version? Generally the newest T train releases are best avoided unless there are specific features that you need that can only be found in those versions.
So the best solution may be downgrading to a version that's known to be more stable. TAC may be able to give advice on which version to go to.
Bronze
Change your set command to the itnerface you want it to go out.
set interface fa8/0/0
Or just set it next hop
set ip next-hop x.x.x.x
118
