It looks like you have a speed or duplex miss match on the switch.
set the swicthport speed and duplex manually
and make sure its the same with that configured on the
c2600
e.g
use this command on both router and switch
(config)#speed 100
(config)#duplex full
2. if router is connected as host on the switch, please use a straight ethernet rj45 utp type 5 cable.
