03-26-2012 07:08 AM - edited 03-03-2019 06:31 AM
Hey what is the best USB to serial adapter you guys have found for use with a cisco console cables? my new laptop has no serial.
Dan
03-26-2012 10:43 AM
My first recommendation is the Keyspan High Speed USB to Serial converted - this is the adapter which I've experienced the least number of issues with.
Second would be the Startech USB to Serial adapter. (It is generally cheaper, as well)
03-27-2012 11:48 AM
i use the cables from Lindy, works also well.
Patrick
03-27-2012 12:27 PM
I've had a good experience with the Trendnet TU-S9.
Edit to add: I have also had mixed luck with Parasini SD1000 serial-to-bluetooth adapter. It's convenient when it works, though.
08-25-2015 06:41 PM
Agree what Brad says,
I work configuring RTs, SW and Access Points(Air -Lap), too, and I have never reported any issue with my Trendnet TU-S9 console cable, it has been always working fine!!!!
regards
11-01-2012 09:42 PM
Here is an explanation to help you decide before you buy: 5 steps to the right USB serial adapter. I pesonally use their part XS880 adapter which works with most of the consoles Im working with.
11-01-2012 09:54 PM
They are exactly all the same based on the same materials and standard. It differs from a model to another the cosmetic and the driver availability (essential) . I tried hundreds of them and you really can't notice any relevant difference. Forgetting... The price does change!!!! I am working since 8 years with the same and never an issue :)
Hope this helps
Alessio
