Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
when to you cat5 cables - for crossover or straight through
I am only a learner, I want to know what cat5 cables connect what up and how to identify which is a crossover and which is a straight through.
I know that if you hold the jacks together on one the orange is all on the left and on the other the other is left and right.
I need to do the following (also please state whether on the switch or hub it needs to go in uplink or normal port)
pc - hub
hub to router
pc to router
pc to switch
switch to router
router BRI to ISDN simulator
any other cat5 configurations you can think of, as I might need to know later on as the training progresses.
thanks all that help me
Silver
Re: when to you cat5 cables - for crossover or straight through
To identify a crossover check the pins, 1 & 3 and 2 & 6 are crossed:
1 -> 3
2 -> 6
3 -> 1
4 -> 4
5 -> 5
6 -> 2
You would need the following type of cable for:
pc - hub -> Straight through - Normal port
hub to router -> Straight through - Normal port
pc to router -> Crossover - Normal port
pc to switch -> Straight through - Normal port
switch to router -> Straight through - Normal port
router BRI to ISDN simulator -> Straight through - Normal port
others you have missed would be
hub to hub -> Crossover (or uplink port)
switch to switch -> Crossover (or uplink port)
Nornally uplink ports are only used to connect switches or hubs to each other, however some uplink ports require crossover cables and some do not, this will depend on the manufacture of the device.
the need for a cross over or straight through cable is well understood if you understand to classify the equipment as a DTE or DCE. DCE provides clocking for DTE equipments.
A DTE device can communicate with a DCE device with a straight through cable. (Tx - Tx, Rx - Rx)
A DTE to DTE communication, or DCE to DCE communication requires a crossover cable.
PC, Router etc are DTE devices
Hub, Switch, ISDN simulator are DCE devices.
You do the rest of the math.
289
