Webcast-Catalyst9k
Which Catalyst model allows transmitting on a SPAN port?
Hi Experts.
I need to design a CiscoIDS-based solution for a Customer and I will need a Catalyst switch.
As far as I know, all Catalyst models will allow the CiscoIDS to *receive* traffic on a SPAN port but not all of them will allow the IDS to *send* packets on SPAN ports (bidirectional SPAN port). Am I correct? Which models support bidir SPAN ports?
Also, which models support private vlan or protected port?
Thank you
michele
1 ACCEPTED SOLUTION
Re: Which Catalyst model allows transmitting on a SPAN port?
The 3550 running IOS 12.1(12c)EA1 and later has support for IDS repel/report traffic, specifically. It isn't general input-packet support.
-A
CAT OS based switches support inpkts on SPAN destination port which will allow the SPAN destination port to received traffic.
CAT4k with Sup3/4 support similar feature starting 12.1(19)EW
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_1_19/config/span.htm#1036989
Hi.
Thanks for you answer.
I've heard that the cat3550 too supports inbound packets on SPAN ports.
Can you please confirm?
Thank you
-A
92
