Webcast-Catalyst9k
which network protocol analyzer for SPAN capture?
I have to do SPAN captures and I?m using Ethereal to analyze the traffic.
I?m disatisfied with Ethereal because my capture files are very big and it failed to open them or it takes ages to open them.
What are the alternative software that I could use?
I also would like to filter packets on packet lenght but Ethereal doesn?t support it.
thanks a lot in advance for your advice.
Laurent
Re: which network protocol analyzer for SPAN capture?
Try to do it with IRIS. It's working better.
hello,
Thanks for the reply.
it would be bettter ffor me if the software would be a freeware.
Anybody knows about any freeware better than ethereal?
Thanks, Laurent
Hall of Fame Super Bronze
Laurent,
Have you tried Packetizer from http://www.networkchemistry.com/products/packetyzer.php ?
118
