Which parameters are require to connect two remote offices??
Which parameters are require to connect two new  remote offices and  which technology is best to connect these two offices? and how to calculate bandwidth requirements?
Hall of Fame Super Gold
First thing you need is to know what kind of applications does the staff in these two offices will be using?  Emails?  Web?  Mainframe?  Voice?
Next thing you need to know is how many staff?  What is the budget for the WAN link?  How important are either of the two sites?
You can use the quick-and-dirty DSL as a WAN link.  But you also need to consider that DSL has a "best effort" SLA.  This means if your DSL link goes down or has a problem, the ISP can take it's time to help you.   If either one or both of the sites are very important, then you may need to stay away from DSL.
Thank you for your valuable
Thank you for your valuable reply
I want to know deeply in this topic.If you know any documents, then please share to me.
Thanks.
78
