Why are iBGP routes not being redist into RIP ?
Can someone please help and explain why this configuration is not working correctly. I am trying to get my 3 iBGP subnets redistributed into RIP in order to send them via RIP to the PIX connected via eth0. iBGP works fine and does what it needs to do. However, I cannot see the iBGP routes being redist when I sho the RIP database. thanks !
OPS_CORE#wr t
Building configuration...
Current configuration : 2151 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname OPS_CORE
no logging buffered
logging rate-limit console 10 except errors
enable secret <del>
enable password <del>
memory-size iomem 20
ip subnet-zero
no ip finger
ip audit notify log
ip audit po max-events 100
no ip dhcp-client network-discovery
interface Ethernet0
ip address 172.16.2.2 255.255.255.0
no ip redirects
no ip route-cache
no ip mroute-cache
half-duplex
interface FastEthernet0
ip address 192.168.5.249 255.255.255.0
no ip redirects
no ip route-cache
no ip mroute-cache
speed auto
router rip
version 2
no validate-update-source
redistribute bgp 65000
passive-interface Ethernet0
network 172.16.0.0
neighbor 172.16.2.1
default-metric 1
no auto-summary
router bgp 65000
no synchronization
bgp log-neighbor-changes
timers bgp 5 16
neighbor 192.168.1.252 remote-as 65000
neighbor 192.168.1.252 update-source FastEthernet0
neighbor 192.168.1.252 default-originate
neighbor 192.168.1.252 route-map NEXTHOP_OVERRIDE_AIR in
neighbor 192.168.4.253 remote-as 65000
neighbor 192.168.4.253 update-source FastEthernet0
neighbor 192.168.4.253 default-originate
neighbor 192.168.4.253 route-map NEXTHOP_OVERRIDE_HAM in
neighbor 192.168.7.254 remote-as 65000
neighbor 192.168.7.254 update-source FastEthernet0
neighbor 192.168.7.254 default-originate
neighbor 192.168.7.254 route-map NEXTHOP_OVERRIDE_WAX in
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.2.1
ip route 192.168.1.252 255.255.255.255 192.168.5.243
ip route 192.168.4.253 255.255.255.255 192.168.5.244
ip route 192.168.7.254 255.255.255.255 192.168.5.244
no ip http server
route-map NEXTHOP_OVERRIDE_HAM permit 10
set ip next-hop 192.168.5.244
route-map NEXTHOP_OVERRIDE_WAX permit 10
route-map NEXTHOP_OVERRIDE_AIR permit 10
set ip next-hop 192.168.5.243
banner motd ^C FOR AUTHORIZED USERS ONLY!!! ^C
line con 0
transport input none
line aux 0
line vty 0 4
password <del>
login
end
OPS_CORE#sho ip bgp
BGP table version is 4, local router ID is 192.168.5.249
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*>i192.168.1.0 192.168.5.243 0 100 0 i
*>i192.168.4.0 192.168.5.244 0 100 0 i
*>i192.168.7.0 192.168.5.244 0 100 0 i
OPS_CORE#sho ip rip data
0.0.0.0/0 auto-summary
0.0.0.0/0 redistributed
[0] via 0.0.0.0,
172.16.0.0/16 auto-summary
172.16.2.0/24 directly connected, Ethernet0
OPS_CORE#
Re: Why are iBGP routes not being redist into RIP ?
I tested this on lab, and was perplexed to find the same results. The ibgp routes were not being redistributed into rip. Not just RIP, it didnt get redistributed via EIGRP, OSPF...Spent almost an hour behind this, thinking why its happening. Finally came to conclustion that, the reason has to be the design of BGP. IBGP routes shouldnt really be redistributed to IGP, because it can cause routing loops.
While browsing through the cisco website, i came across a command, called "bgp redistribute-internal". This command can be used to enable redistribution between iBGP routes and IGPs. By default a cisco router doesnt redistribute between iBGP and any IGP, to prevent possible routing loops.
The cisco document says that this is used to redistributes routes into IGPs such as OSPF and IS-IS. But I have tested this with RIP and it works with RIP too.
Use this command with extreme care, because this can be a potential source of routing loops in your network. The CLI command description itself describes it as "dangerous".
1600(config-router)#bgp ?
always-compare-med Allow comparing MED from different neighbors
bestpath Change the default bestpath selection
client-to-client Configure client to client route reflection
cluster-id Configure Route-Reflector Cluster-id
confederation AS confederation parameters
dampening Enable route-flap dampening
default Configure BGP defaults
deterministic-med Pick the best-MED path among paths advertised from
the neighboring AS
fast-external-fallover Immediately reset session if a link to a directly
connected external peer goes down
log-neighbor-changes Log neighbor up/down and reset reason
redistribute-internal Allow redistribution of iBGP into IGPs (dangerous)
router-id Override configured router identifier
scan-time Configure background scanner interval
Also a min of 12.1 IOS is required to use this command.
HTH.
Thank you, I appreciate very much the time you spent looking into this. I will add that to my BGP process and see what happens..
166
