why bakebone fast cann't work with GEC(giga etnernet channel)?
two cat6513 and four cat4006
every 6513 have two WS-X6K-S2-MSFC2
one WS-X6516-GBIC
WS-X6348-RJ45V
every cat4006 have eng supIII
WS-X4148-RJ
every cat4006 G1/1 connect 6513A ;G1/2 connect 6513B
two cat6513 config GEC (3/1-2 port channel)
G3/1 G3/1
G3/2 G3/2
6513A ------------------ 6513B
GEC
4006 config:
spanning-tree uplinkfast
spanning-tree backbonefast
interface GigabitEthernet1/1
switchport trunk encapsulation isl
switchport mode trunk
description connect to 6513A
no snmp trap link-status
interface GigabitEthernet1/2
description connect to 6513B
6513A config
#system
set system name 6513A
set system highavailability enable
#backbonefast
set spantree backbonefast enable
set trunk 3/1 on isl 1-1005,1025-4094
set trunk 3/2 on isl 1-1005,1025-4094
set trunk 3/3 on isl 1-1005,1025-4094
set trunk 3/4 on isl 1-1005,1025-4094
set trunk 3/5 on isl 1-1005,1025-4094
set trunk 3/6 on isl 1-1005,1025-4094
set trunk 3/7 on isl 1-1005,1025-4094
set port channel 3/1-2 mode on
set spantree root
6513B config
#system
set system name 6513B
#backbonefast
set spantree sec
I had trouble for all cat4006 CPU utilization was 99%!!!!
among of them
Cat4k Mgmt LoPri 70.44%
Spanning Tree 28.94%
MY operatetion :
I sent reset 1 on 6513A all is OK
but I sent reset 1 on 6513B
then the message is report the G3/1 and G3/2 all disconnet the Port-State 3/1-2 was not-connect!!!???
so I add a command set errdisable-timeout enable channel-misconfig on two 6513 ,late 30s the GEC Port-State is OK.
but now all the 4006 CPU utilization was 99%!!!!!!
final i remove backbone fast in all cat4006 .
all 4006 CPU utilization was 99% is fall to 5%.
then I add backbone fast cat4006 CPU utilization was 5% also,
but I try change the GEC port channel (set port channel 3/1-2 on change set port channel 3/1-2 desire)
right now the 4006 CPU utilization was up to 99%
my conclusion is when the GEC is change the cpu utilization is up to 99%
so I hvae two question !!!
fist : why I reset 6513A modu 1,then reset 6513B modu 1 ,the GEC change not-connect
two : cisco suggest all switch configure backbne fast,why now it is trouble.
1 REPLY
Silver
Re: why bakebone fast cann't work with GEC(giga etnernet channel
98
