Why for Default Gateway IP address in Switch!!!
Hi All,
To assign an IP address to the management VLAN (default is VLAN 1)
Cmd are:
Switch(config)# interface vlan vlan-id
Switch(config-if)# ip address ip-address netmask
Switch(config-if)# ip default-gateway ip-address
Switch(config-if)# no shutdown
1.I can't understand why for the Default gateway address is needed in this. 2.Whether the Default Gateway should be in the same subnet as the IP address of the Management VLAN(ie., VLAN1)
Is the below cmd mandatory:
Kindly help in this issue.
Thanks in Advance!!!!
GuruPrasad.R
Bronze
Re: Why for Default Gateway IP address in Switch!!!
Morning GuruPrasad.R,
Good question. The default gateway servers the same purpose as a configured default gateway on a switch. If your intention is to manage the switch from a remote VLAN/subnet you must configure an IP default gateway who can forward the traffic between VLANs.
Similar to PC and IP gateway, proper configuration requires the default-gateway and switch IP to be in the same subnet.
One last thing, I believe the IP default-gateway is a global configuration command.
HTH,
Ryan
Bronze
The default gateway needs to be in the same subnet as the Management VLAN. When the Mgmt. vlan needs to talk to anything within the same subnet, it issues an arp for the IP address to find the mac address so it can complete the packet build and establish communication. If it tried to do the same for something outside of its subnet, it would not get a response (in most situations). As such, it needs an IP to send info to for anything outside its subnet.
The ip default-gateway command is a global config command, not an interface config command. If you are using a multi-layer switch, it is better to use the
ip route 0.0.0.0 0.0.0.0
command. Hope this helps.
Hall of Fame Super Silver
In answering this question I believe that we need to distinguish between a layer 2 switch and a layer 3 switch. A layer 3 switch with routing enabled does not need and does not use a default-gateway (but it will probably need a default route). A layer 2 switch does need and does use a default-gateway. A layer 2 switch has the same kind of IP stack as a PC. They layer 2 switch operates as an IP host on the network. As such it will ARP for addresses in its local subnet and will forward to its default gateway for addresses outside of its local subnet.
From that fact we can also answer the second part of the question: yes the default-gateway should be in the same subnet as the address configured on the switch.
Rick
250
