why I could not execute "sh flash" on UBR7223?(ergent!!!)
On a UBR7223,I inserted a PCMCIA in slot0,the system boot from it normally.I can use "dir disk0:"etc command on the ubr7223,
but I could not use "sh flash","dir slot0:"!I have the following questions:
1.Is disk0 slot0?Are they same?
2.if the above answer is "yes",why I encouter such kind of problem?
3.If the above answer is "no",could you give me a clear explaination?
Thanks in advance!!!
Some info I copied from the machine Ubr7223:
Router#dir slot0:
%Error opening slot0:/ (Bad device info block)
Router#sh flash file
Error getting file system status.
Router#sh flash all
Open device slot0 failed (Bad device info block)
Router#sh disk0:
******** ATA Flash Card Geometry/Format Info ********
ATA CARD GEOMETRY
Number of Heads: 4
Number of Cylinders 735
Sectors per Cylinder 32
Sector Size 512
Total Sectors 94080
ATA CARD FORMAT
Number of FAT Sectors 46
Sectors Per Cluster 8
Number of Clusters 11708
Number of Data Sectors 93920
Base Root Sector 220
Base FAT Sector 128
Base Data Sector 252
  • Other Network Infrastructure Subjects
1 REPLY
Bronze
Re: why I could not execute "sh flash" on UBR7223?(ergent!!!)
Here is a link which describes in detail , how the UBR7223 boots with a flash and PCMCIA card.
http://www.cisco.com/warp/public/130/sw_upgrade_highendrouters_23233.html
http://www.cisco.com/warp/public/63/pcmciamatrix.html
ATA PCMCIA Flash disks use different command syntax when referring to the PCMCIA slot. Substitute the command syntax disk0: or disk1: if you are using an ATA PCMCIA Flash disk instead of slot0: or slot1: which refers to Linear PCMCIA Flash memory cards. When you see an error message such as "%Error opening slot0: (Device not ready)", try using the dir disk0: command
332
