Webcast-Catalyst9k
Why is everything on my Frame-relay network working fine with different encapsulation types ?
I have a cisco frame-relay switch with the encapsulation type on IETF.
I have a cisco router with
the encapsulation type on cisco.
Still everything works fine.
How come when it is a different dlsi byte structure ?
Is it because also my switch is a cisco and it uses cisco encap afterall ?
1 REPLY
Anonymous
N/A
Re: Why is everything on my Frame-relay network working fine wit
A cisco router will understand both the IETF and normal Cisco encapsulation when receiving data regardless of configuration. However, depending on the configuration, it will only send one type.
118
