why isn't there any log for serial interface when ISDN kick in, in the log file
admin_2
Level 3
Level 3
Currently having a ISDN(BRI) backup when Leased line in down. Both interface is different but resides in the same router. In the log file, it shows that the isdn kick in but it did not indicate any serial interface down , why?
Not applicable
Make sure that logging is not disabled
on the serial interface. Otherwise, if
you are using anything besides the
"backup interface" command to provide
backup (ie dialer watch, floating static
routes, etc) then it could be that
dialing occurred due to your config. You
can enable "debug dialer" to see what
traffic caused dialing to occur.
