why we use network module
engamb1991
why we use network module ? what is the purpose of it
When you buy a switch or router, it comes with some default interfaces and some empty slots.
Default interfaces are usually ethernet interfaces; however, router or switch support more different kinds of interfaces. You can order and buy those interfaces depending on your needs. New interfaces comes in the forms of modules can be put inside those empty slots. Suppose you need to etablish a WAN connection between two different locations. So you need to buy a WAN module. It is like buying a ethernet card for your computer. Or you need to connect fiber cables to your router, so you need to buy a module with fiber interfaces.
There are two types of module and also two different slots on routers. Smaller slots are for WIC and bigger for NM (Network module)
1-Network module(your question).
This is a bigger module that can hold a variaty of ports and also some NM modules and some WICs. These module usually can be inserted in bigger routers.
2-
WIC is smaller card that can be inserted in a router dirrectly or in some NM card.
WIC and NM are a little old and today HWIC and NME are mostly used.
Please check the link below to check different kinds of module for router 2800. Take a look at the modules with the prefix of NM, NME, WIC, HWIC.
http://www.cisco.com/c/en/us/products/routers/2800-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
Hope it helps,
Masoud
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If you're asking about hardware modules that are inserted into a network device, it allows the network device to provide different capabilities without the need to swap the whole device and/or without provide many features that would otherwise not be needed.
For instance, on a small ISR, a network module might allows for the addition of Ethernet ports, special WAN media, or it might support hardware acceleration of some special feature.
2-
Hope it helps,
Masoud
