Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Why Would an X.25 Serial Interface Be Up/Down during send and receive Data over X.25/XOT?
Scenario:
PC===Cisco2501/X.25===V.24-Modem==<>==V.24-Modem====Cisco2522/X.25====XOT-Tunnel====MainframeBS2000
There is the Situation that after a while the Int-S1 on Cisco2522/X.25 sets the Line-Protocol down,
then the Interface down. After ca. 5 seconds the Interface comes up. In betweentime the client-PC requests
the X.25-Call to the Host. When Interface is up the Call will be initiated, Connection is up.
There are no errors occured in the syslog or in debug-mode.
1 REPLY
Anonymous
N/A
Re: Why Would an X.25 Serial Interface Be Up/Down during send an
The problem could be physical or
at layer2 (LAPB). If we lose connectivity
at layer2, for whatever reason,
LAPB will try to restart itself (by
sending a SABM) and if we don't receive
a UA the line protocol will go down.
You can have a look at "debug lapb"
to see if this indicates a problem;
also check out the interface stats to
ensure there are no errors or drops.
Finally, you might ensure the configs
of the V.24 modems, to verify that they
are configured the same (since it sounds
like one end has a problem, the other
doesn't).
205
