Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
WIC-1B-s/t card for Cisco 1603
Hi .
I want to install a wic card in my Cisco 1603 R ( 8Mb Dram, 4MB Flash) Is there any special requirement ( memory etc..)to install it ? Thanks
Manel
1 ACCEPTED SOLUTION
Silver
Re: WIC-1B-s/t card for Cisco 1603
Yes, should work fine without any issues.
Thanks, Mak.
Silver
The memory will depend on the IOS image you decide to use.
Please refer to:
http://cisco.com/kobayashi/sw-center/sw-ios.shtml
Thanks, Mak.
Hi Mak
The IOS ver. is IP 120-4.T , and nothing special in the configuration that can affect to the memory resources such as routing protocols etc..
Version that you have will work fine with routing protocols and bri card.
Silver
Thanks, Mak.
92
