WIC-1ENET problem on Cisco 1721
I have got a Cisco 1721 router running on the Cisco 1700 Ser IOS IP PLUS IPSEC 3DES (ver 12.2(10) IOS. I have tried to install an additional ethernet interface using the WIC-1ENET card. The problem is the WiC-1ENET Card is not being detected on the router. What can I do to go around this problem? I still need the IP Plus IPsec 3DES feature.
1 REPLY
Re: WIC-1ENET problem on Cisco 1721
You can refer to the documentaion of the WIC if there is any restrictions.
Sometimes and also depending on the IOS, you can install the WIC only in Slot0, and only one WIC can be installed on the router. I had a similar situation once.
Try the "show diag" and the show "hardware" commands to verify.
Hope it helps
178
