WIC-2T problem with 1721 Router
hi,
we were using 1600 router for connecting data leased line(v35) to our branch office.Now for connecting one more line,we changed it to 1721 with wic-2T..the problem is only serial 1 works ,when connected to serial 0,it's giving error serial 0 up,line protocol down.once connected it will b up for 2min..then goes down...when connected to serial 1,it works fine.so i replaced interface card also,still same problem,replaced router also,still same.cables alsoworking fine....what can b the problem...is there any Wic-2T compatibility issue with 1720...
waiting for a solution!!!
-Deepak
1 REPLY
Bronze
Re: WIC-2T problem with 1721 Router
Hi Deepak, the only restriction I know of is that you should always use wic slot 0 in single wic card configurations on the 1720/1.
Another link describes the symptoms you are experiencing but hasn't been resolved.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.eea1ab3
If you aren't in slot 0, try it.
If you don't get an answer here then it's probably time to raise it with TAC.
238
