Will VoIP over BRI in backup mode work when the T1 fails?
Scenario: (2) 3640's each with (1)T1 to PBX for VoIP ( 8 channels of T1 using G.729). The 3640's are connected on the WAN using a Single T1 using either PPP or Frame. A single BRI is used for dial back. Question: Will VoIP over BRI in backup mode work. Will at least a few voice calls work?
1 REPLY
Anonymous
N/A
Re: Will VoIP over BRI in backup mode work when the T1 fails?
Yes a few calls would work but you have to ensure the right QOS is in place. LLq and LFI. Also under the voip dial-peer, you might want to limit the number of acceptable calls so that we dont oversubscribe the isdn 128kb link.
g729 = 26Kb/s for one voice call with no crtp
i.e you can only have 75% of 128/26 calls for good quality to
be achived =3 calls.
If doing crtp then one voice call now uses 12KB/s and you can have
8 calls.
The command to use to limit accepted call under dial-peer
is " max-conn "
96
