01-09-2003 08:37 PM - edited 03-02-2019 04:04 AM
I posted this message a couple of weeks ago in another forum but have not had any helpful replies. Perhpas someone here knows the answer?
_____
I am using Hyperterminal 5.1 (WinXP Pro) as console to a C827. I encounter a very annoying problem. When I hit up arrow to repeat a command, instead of the command repeating I see the following output:
^@ <Carriage Return>
My configuration is as follows:
9600 BPS
8-N-1
VT100 Emulation
All other settings are at Hyperterminal default.
01-13-2003 10:00 AM
i have heard you need to download the private edition, i haven't tried it yet, but have been told this will give you the ability to use the up arrow to repeat commands without having to type them
01-13-2003 04:49 PM
Yes, Private Edition worked for me. I was having the same problems listed. Working fine now
