Community Member
Wireless Barcode Network Data Transmission problem
We have a Barcode application running under SCO UNix 5.0.5. The barcodes
are read on our shop floor using Symbol Scanners attatched to Wyse 60
Terminals attached to ports on a digi port server. The port servers are
wired to a Cisco Aironet Bridge which sends a Wireless signal to a Cisco
Access point, which is connected via a Cisco Switch to our Unix Server.
Occasionaly, a barcode will be scanned AND registerd as a good scan, but the
part of the barcoded data is replaced with other characters. (Eg: If I
have a barcode which clearly should read as 1234, it will read 1 time out of
30 as 12&4). I thought that this might be the result of a transimssion
error somewhere in the wireless portion of the network, since the barcode
scans correctly most of the time and only occasionally (irrespective of the
terminal bing used) send the incorrect information to the server. Has
anyone seen this with Wireless Appliances before? Is there a solution?
Thanks in advance
Ad
Bronze
Re: Wireless Barcode Network Data Transmission problem
The Wireless devices like Aironet bridge or AP are Layer 1/2 devices, so the error checking should be handled by the higher layer devices or applications. Check with Barcode application vendor if there is any error checking mechanism builtin the application.
I would also work with a sniffer on this one and work along the line to start to finish to see where (if anywhere) packets are getting dropped. You would be looking for Ethernet II packets with an Ethertype of 8780 - 8785 (they belong to Symbol). Also look for the Symbol MAC address.
Hope it helps.
Steve
108
