Community Member
With a WS-X4232-L3 module in a Catalyst 4000, do you still need an external router? If not, how do you configure the routing engine?
If the WS-X4232-L3 is the routing engine, then how do you configure it to route or do you still need an external router connected to the Catalyst 4000? If the WS-X4232-L3 is the router then which document specifies the routing commands?
1 REPLY
Anonymous
N/A
Re: With a WS-X4232-L3 module in a Catalyst 4000, do you still n
no you don't need the external router to do any routing. it can be done using this module.
Here is the config sample.
http://www.cisco.com/warp/customer/473/28.html
243
