Webcast-Catalyst9k
WLSE not showing reports
WLSE 2.0.2 software running on an 1105. When I go to Administration, Discovery, Run Now, I put in my seed device and hop, press finish and get a message indicating the report ran. I press okay, and go to view the reports but they are not showing. The last discover I ran was #34. Subsequent reports should be 35, 36, etc... but they don't show. Any ideas?
Re: WLSE not showing reports
It takes a while for it to show up. Once 34 completes, then you can see 35 and so on and so forth.. How long has it been ?
Highlighted
it's been a couple of hours. I'm only discovering 1 AP and 1 switch. Discoveries 31-34 were instantaneous.
Are you sure about the SNMP community string ? Are you able to see those devices in the managed / unmanaged devices list ?
It'll be easier to work on this with a TAC case.
I did the SNMP reachability test and it showed SNMP objects for the switch and AP. I don't see the devices in the managed/unmanaged devices list. I have a TAC case open. They want me to upload some log files on Monday. I think the TAC engineer is stumped too.
101
