worried problem
I have two routing domain.One is rip domain,the other is ospf domain.All of them belong to a main network,but the ospf have the specific mask.To redistribute ospf route to rip,why create serveral static route ,then redistribute them into rip.Who can give me answer as soon as possible?
1 REPLY
Re: worried problem
I'm not sure what you want to do makes any sense.
If OSPF is advertising the more specific routers (longer prefixes), and RIP the more general routes (shorter prefixes), the routing table should have both. The shorter prefixes inserted from RIP, and the longer prefixes from OSPF.
Please explain you situation a little more clearly.
HTH,
Joe
94
