WRED
When enabling WRED you can avoid dropping packets and instead mark them with the ECN bits
The idea is that the end hosts and routers can lower down the throughput
How do you enable a host or router to lower the rate when receiving an ECN
1 ACCEPTED SOLUTION
Re: WRED
The end hosts also need to be ECN-aware to make use of this (RFC3168 support?). If the end-host's TCP/IP implementation supports it I'm guessing it might be enabled automatically; would depend on the OS/vendor.
Quick lookup in Solaris 10 shows that ECN is enabled passively by default i.e. it will only negotiate it if the other end-host requests it otherwise not. The setting can also be changed to actively negotiate it or turn it off completely
Re: WRED
Please check the below document .. I hope it helps ...Please rate it if it does !!!
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080443160.html#wp1028640
On your routers you need something similar to the below config :
Router(config)# policy-map pol1
Router(config-pmap)# class class-default
Router(config-pmap)# bandwidth per 70
Router(config-pmap-c)# random-detect
Router(config-pmap-c)# random-detect ecn
Re: WRED
310
