Community Member
Wrong system software for this hardware
I install a IOS for the router 2514, but it presents the seg message : Wrong system software for this hardware...
I don't know booting
only in rxboot, I want the system back again.
1 REPLY
Anonymous
N/A
Re: Wrong system software for this hardware
Follow these steps to recover your router.
Copy a new 2500 image to tftp from cco.
router(boot)# copy tftp flash
It might prompt a question copy flash with erase y/n?
After completion of the download
router(boot)# reload
_Note_ a question system configuration as been modified do you want to
save y/n ?
answer no.
If you pick yes you will overwrite you configs will be nvram with an empty config.
236
