05-16-2006 06:11 AM - edited 03-03-2019 03:14 AM
I have configured this on a 2900XL before and I did not have any problem. Today I went to configure a 2900XL. I went into VLAN DATABASE and said
vlan 40 name building4
and then exit.
I went to config terminal and configured:
interface fa0/24
switchport access vlan 40
switchport mode access
no shut
int vlan40
no shut
end
Now when I do show run it shows a shutdown statement under VLAN 40 and
show int vlan 40 shows that it is administratively down.
What am I doing wrong?
05-16-2006 06:18 AM
Probably there is another management vlan configured on that switch. These are layer 2 switches that can only have a single management vlan. If you need the vlan 40 to be the management vlan shutdown the other vlan and then try doing a no shut on the vlan40. You might also be required to enter the command 'management' under vlan 40 to make it operational.
05-16-2006 06:24 AM
Remember this is a layer 2 switch . You can only have one layer 3 SVI active at one time and it will shutdown all others . The ip is to manage the switch only and has no routing function . If you want to use vlan 40 as the management vlan then you have to manually shutdown vlan 1 or whatever vlan is currently up and then "no shut" vlan 40 . Obviously then your ip addressing and default gateway would have to be in the correct subnet of the layer 3 router supporting this switch.
