WS-C3750-48P system error message... need help
All,
Does anyone come across to this system error massages on 3750 switch? I can not find any ref regard this error from Cisco website.
Feb 10 22:32:41.262 UTC: %SUPERVISOR-3-IIC_INIT: IIC Reinitialized
Feb 10 22:35:54.284 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up
Feb 10 22:35:58.545 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to down
Feb 10 22:36:05.525 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up
Can any tell me what the messages means and why it occurs? Thanks in advances
regards,
Sean
Re: WS-C3750-48P system error message... need help
What IOS version is the switch running? The message:
What kind of media converter is on interface gig 1/0/1? I am thinking it's related to that interface flapping. Is the error peristent? If it is, does the error stop when you shut down the interface gig 1/0/1?
Media type is 1000BaseSX SFP
IOS version is 12.2(25)SEB4
It disappear after a reload. But I really want to find the root cause to prevent it happens again. It bring down the the interface everytime it happens.
do you know what does "IIC Reinitialized" means?
Found the bug.. CSCee92228
Thanks everyone who tried to help.
Check out bug:CSCee88632 too. I can only say that interface controller register access failed because of IIC bus lockup - maybe due excessive flap of the interface. switch s/w cannot do anything under such circumstances but log an error.
bosalaza,
You could be right. Nobody touch the switch during this problem occurred. I may need to research more on this issue. Thanks
regards,
sean
373
