08-20-2003 03:57 AM - edited 03-02-2019 09:44 AM
Anyone know of any reasons why MAC addresses wouldn't be learned when servers are connected to the 10/100/1000 48 port RJ45 WS-X6548-GE-TX card, when we swap them to a 10/100 RJ45 WS-X6148-RJ-45 card we have no problems.
IOS is 12.1(19)E and the card is supported on this.
08-20-2003 04:41 AM
Can you paste the output of
remote command switch show platform hardware asicreg revati slot X port, where X is the slot number?
I'm checking to see if you are hitting the following bug
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCeb84900
08-20-2003 04:54 AM
It doesn't seem to like that command:
#remote command switch show platform hardware asicreg revati slot 11 port
Line has invalid autocommand "show platform hardware asicreg revati slot 11 port
08-20-2003 05:00 AM
Can you paste the output of sh ver
08-20-2003 05:15 AM
Here's a show version:
#sh ver
IOS (tm) c6sup2_rp Software (c6sup2_rp-JK2SV-M), Version 12.1(19)E, EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Sat 31-May-03 16:12 by hqluong
Image text-base: 0x40008C00, data-base: 0x41CBE000
ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1)
BOOTLDR: c6sup2_rp Software (c6sup2_rp-JK2SV-M), Version 12.1(19)E, EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
cetcrt001 uptime is 4 weeks, 5 days, 22 hours, 9 minutes
Time since cetcrt001 switched to active is 4 weeks, 5 days, 22 hours, 8 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 17:05:32 MEST Thu Jul 17 2003
System image file is "sup-bootflash:c6sup22-jk2sv-mz.121-19.E.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco WS-C6513 (R7000) processor (revision 1.0) with 458752K/65536K bytes of memory.
Processor board ID TBM06481844
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
2 Virtual Ethernet/IEEE 802.3 interface(s)
48 FastEthernet/IEEE 802.3 interface(s)
116 Gigabit Ethernet/IEEE 802.3 interface(s)
381K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
Standby is up
Standby has 458752K/65536K bytes of memory.
Configuration register is 0x102
08-20-2003 05:04 AM
I now have the output:
-sp#sh platform hardware asicreg revati slot 11 port 48
0000: 0002
0001: 0020
0002: 0006
0003: 1800
0004: 0497
0005: 00FF
0006: 0000
0007: 03EE
0008: 5555
0009: 0000
0020: 0180
0021: C200
0022: 0020
0023: 0100
0024: 0CCC
0025: CCCD
0026: 0000
0027: 0000
0028: 0000
0029: 8100
002A: 00FF
002B: 0000
002C: 0000
002D: 1085
002E: 6FE6
0040: 0000
0041: 0000
0042: 0000
0043: 0002
0044: 0001
0045: 02AF
0046: 0000
0047: 40FF
0048: 0178
0049: 0000
004A: 0000
0080: 0000
0081: 0000
0082: 0000
0083: 0000
0084: 0000
0085: 0000
0086: 0000
0087: 0000
0088: 0000
0089: 0000
008A: 0000
008B: 0000
008C: 0000
008D: 0000
00A0: 0000
00A1: 0000
00A2: 0000
00A3: 0010
00A4: 0000
00A5: 0000
00A6: 0000
00A7: 0000
00A8: 0000
00A9: 0000
08-20-2003 05:37 AM
Is something connected to this port? If not can you connect a device and if it is having connectivity issues, paste the output of
"sh platform hardware asicreg revati slot 11 port 48 error-count"
The counters are cleared on read
08-20-2003 05:57 AM
There's nothing connected as we had to move the servers off this card onto another 48 port 10/100 card in order to get them to work, but yesterday when we had a laptop connected we saw the issue on a different port in slot11, however it's not on there now.
Just looking at an ARP packet it is 42bytes on the wire, so coule we be looking at the problem described in the bug you mentioned?
08-20-2003 06:37 AM
The counters do not indicate you are hitting this bug. I suggest that connect few devices on the 6548, recreate the problem and open a TAC Case for this one
08-20-2003 07:22 AM
Thanks for your help, we already have a case open.
