08-19-2003 05:27 PM - edited 03-02-2019 09:43 AM
Hi all,
I have a problem whereby PAD to a Alcatel HLR 1422 results in this error debug message. Keypoint here is Diag 235.
00:05:16: Serial0/1: X.25 O R1 Call (13) 8 lci 1
00:05:16: From (4): 2001 To (4): 1001
00:05:16: Facilities: (0)
00:05:16: Call User Data (4): 0x01000000 (pad)
00:05:16: Serial0/1: LAPB O CONNECT (15) IFRAME 6 4
00:05:16: Serial0/1: LAPB I CONNECT (2) RR (R) 7
00:05:16: Serial0/1: LAPB I CONNECT (7) IFRAME 4 7
00:05:16: Serial0/1: X.25 I R1 Clear (5) 8 lci 1
00:05:16: Cause 0, Diag 235 (DTE originated/Unknown diagnostic)
00:05:16: PAD: VC Cleared Cause: 0 Diag: 235
00:05:16: Serial0/1: X.25 O R1 Clear Confirm (3) 8 lci 1
00:05:16: Serial0/1: LAPB O CONNECT (5) IFRAME 7 5
00:05:16: PAD: VC Out of service/deleted
00:05:16: PAD0: Closing connection to . In 0/0, out 0/0
00:05:16: Serial0/1: LAPB I CONNECT (2) RR (R) 0
I have tried several combinations of configurations which have matched the Alcatel HLR switch configuration and usually results with this debug message.
Please help
08-19-2003 06:39 PM
According to the debug we are getting INPUT clear from device connected to serial 0/1 ,once the router get input clear it would send out clear confirm. we are getting proprietory diagnostic code which is vendor specific , you need to find out from other end why they are sending us clear and what that diagnostic code means .
Can you send running configuration of your router and show interface serial 0/1
08-19-2003 09:00 PM
Thank you for replying
Here is the interface
Serial0/1 is up, line protocol is up
Hardware is PowerQUICC Serial
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation X25, loopback not set
X.25 DCE, address 2002, state R1, modulo 8, timer 0
Defaults: idle VC timeout 0
cisco encapsulation, nvc 8
input/output window sizes 2/2, packet sizes 256/256
Timers: T10 60, T11 180, T12 60, T13 60
Channels: Incoming-only none, Two-way 1-16, Outgoing-only none
RESTARTs 6/0 CALLs 0+9/0+0/0+0 DIAGs 1/0
LAPB DCE, state CONNECT, modulo 8, k 7, N1 12056, N2 20
T1 1000, T2 0, interface outage (partial T3) 0, T4 0
VS 3, VR 2, tx NR 2, Remote VR 3, Retransmissions 0
Queues: U/S frames 0, I frames 0, unack. 0, reTx 0
IFRAMEs 28/17 RNRs 0/0 REJs 0/0 SABM/Es 0/2 FRMRs 0/0 DISCs 0/0
Last input never, output 00:00:34, output hang never
Last clearing of "show interface" counters 01:04:38
Queueing strategy: fifo
Output queue: 0/40 (size/max)
103 packets input, 283 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
93 packets output, 381 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
2 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Here is the configuration
version 12.3
service password-encryption
ip subnet-zero
mpls ldp logging neighbor-changes
no ftp-server write-enable
x25 routing
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
encapsulation x25 dce
x25 address 2002
x25 htc 16
x25 ips 256
x25 ops 256
x25 nvc 8
clockrate 9600
lapb T1 1000
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
x25 address2001
x25 htc 16
x25 ips 256
x25 ops 256
x25 nvc 8
no keepalive
clockrate 9600
no ip http server
ip classless
x25 route 1002 interface Serial0/0
x25 route 1001 interface Serial0/1
line con 0
line aux 0
line vty 0 4
login
transport output none
end
I have looked through with the engineers on the Alcatel side and the configuration looks similar except for T20+ (timer) values which cannot be configured on the current IOS I am running.
08-19-2003 09:31 PM
X25 T20 timer is use to send Restart request in X25 DTE side , the s0/1 is x25 dce in X25 DCE the similar counter you have is x25 T11 which is set in DCE for restart indication, you would not see option of t20 in DCE side.
I am wondering if you turn on keepalive and then see your interface is stay up/up longer w/o turning on keepalive the interface is always stays up/up.
I notice we have couple of interface reset so i want to make sure with keepalive we still see interface stays up/up .
Turn on debug labp and debug x25 all after enabling keepalive and shut/no shut the interface .
Again the clear indication is coming form Alcatel , they need to tell us why are they clearing the call . According to your configuration they are expecting lci within 1-16 , may be they are expecting different channels then we need to change x25 htc paramter accordingly, it is just a guess .
08-20-2003 01:07 AM
Thanks for your input.
I have talked to the Alcatel Engineers and they will refer their configuration as well as mine to their respective parties.
There is this field which is interchangable on the Alcatel switch configuration
Definition: CCITT or ISO
Is this a good clue?
08-20-2003 08:44 PM
CCIT protocol is define the call user data in call set up field , that shows 0 in 8 bit and 0 also in 7 bit in call user data .
In the debug it was showing the CUD field shows 0x01 which is Local PTT protocol also say PAD ..
The question here is how you are making a call to other device of x25 connected to s0/1 .Are you making pad call from router to connect to that x25 device connected in alcatel side or just switching x25 callfrom one side to other using x25 route. It seems to me a pad call coming into the router .
Again you need to involve Alcatel to narrow down the problem , as those are clearing the call with vendor specific reason.
08-25-2003 08:36 PM
Problem solved,
Alcatel switch terminal configuration is set to GENEWAN and LineRemote (not workstation remote). Hope this helps other people.
