X25 active calls over a Serial Interface
How many X25 active calls in a serial interfaces can be managed by a Cisco router?
Two cases:
A) All calls to the same host.
B) Calls to differents host.
If answer to case A is 8 using the nvc parameter, is there some way to reach more simultaneous active calls to the same host?
Thank you very much.
1 REPLY
Bronze
Re: X25 active calls over a Serial Interface
For calls to the same host, I think the maximum number of calls is 8 set with the nvc. If you need more calls, you can use multiple serial interfaces and use hunt-groups. Check this one :
http://www.cisco.com/warp/public/133/x25_load_balancing.html
71
